Autodesk Fabrication Content
Join the Autodesk Fabrication Content community discussions to share your requirements for Building Product Manufacturers’ content.
Active Contributor
bireshwar.mallick
Message 1 of 13 (387 Views)
PEX services in Fabrication CAD MEP
387 Views, 12 Replies
03-26-2014 09:33 PM
Can any body suggest how can we get/download the PEX services for carrying out works so that we can create distribution systems with the PEX systems in AutoCAD Fabrication CAD MEP, it will be of a great help.
Bireshwar
Member
MTBLetsos
Message 2 of 13 (281 Views)
Re: PEX services in Fabrication CAD MEP
05-21-2014 12:27 PM in reply to: bireshwar.mallick
Uponor's website has a downloadable *.iez service file.  It is located under the BIM download, hard to find but worth the search.
Todd
Active Member
CraigFarsh
Message 3 of 13 (244 Views)
06-03-2014 12:33 AM in reply to: MTBLetsos
Hi MTBLetsos
Is Uponor the main manufacturer of PEX piping?
Also do you have a specific link to their .iez, i have had a look on the website but was unable to locate it. Would make sense to add their item data into the ootb configuration.
Regards
Craig F
Active Contributor
bireshwar.mallick
Message 4 of 13 (241 Views)
06-03-2014 01:58 AM in reply to: CraigFarsh
Hi MTBLetsos,
It will of a great help if you suggest the location of the the respective .IEZ pex service.
Best Regards,
Bireshwar
Bireshwar
Member
MTBLetsos
Message 5 of 13 (234 Views)
06-03-2014 05:35 AM in reply to: CraigFarsh
No Uponor is just one of the companies that manufacture PEX.
Member
MTBLetsos
Message 6 of 13 (232 Views)
06-03-2014 05:39 AM in reply to: MTBLetsos
The Uponor PEX (iez) file is attached for your use.
Active Member
CraigFarsh
Message 7 of 13 (230 Views)
06-03-2014 06:47 AM in reply to: MTBLetsos
Hi MTBLetsos
Thank you for clarifying and providing the .iez.
Regards
Craig F
Active Contributor
bireshwar.mallick
Message 8 of 13 (221 Views)
06-04-2014 04:34 AM in reply to: MTBLetsos
Hi MTBLestos,
Thanks a for proving the Uponor PEX service. There are two issues that we have found and the same are stated underneath
Baisc Propex tubing or flex pipe not seen in the propex systems (snap attached)
We are not able to see the long run service to draw basic PEX pipe only a pex tubing service is present in the Uponor AquaPEX tubing. We need to draw basic PEX pipes with all the Uponor system fittings, Manifolds,etc...
When we are drawing between a/the fitting(s) to fitting(s) then errors are shown
Snap attached for illustration purpose.
Bireshwar
Active Contributor
bireshwar.mallick
Message 9 of 13 (219 Views)
06-04-2014 04:36 AM in reply to: bireshwar.mallick
Hi MTBLestos
Joint error attachment with respect to the previous correpondence as we cannot upload multiple image here as such I am replying in a separate thread.
With best regards,
Bireshwar
Active Member
CraigFarsh
Message 10 of 13 (212 Views)
06-04-2014 05:03 AM in reply to: bireshwar.mallick
Hi bireshwar.mallick
I have looked over the parts in this arnge and there are many fundamental errors which will cause problems when drawing.
1. there is no flex tube in this service, that part that is set up as tube is in fact a subassembly and will not work with this range.
2. No spec applied
3. No insulation material set, should this be set?
4. The connectors of the male fittings which appear to couple pipe together, also the main connector for fittings is not configured correctly so will not allow connection to tube.
These are only a few of the issues i have seen in the 10 minutes i have spent reviewing the service. I could quickly fix some of these to allow you to draw something but even this will be a half baked effort. I would like to pass this to our content development team to thoroughly comb through these parts and database conponents and supply a decent set of content. I think it will be a while before this will be a useable range.
Regards
Craig F
