iam new user for camduct its power full
but when i try to write nc code i have problem the camduct write using cutting tool
some side which street must cutting by cutting tool and some part must cutting bu groov tool
any pody can help me
Hi
Are you using the Ductboard Patterns? You cannot use the normal Rectangular patterns as they do not work with Ductboard.
You can find them under HVAC - Generic - Duct Board in your Item Folders.
thank you for replay its now working
but i have one more question when i make nc code for any part all time cutting tool coming over v tool line its not true because the v tool path will damage
