thanks for the reply fitz
it must be our network setup, I am pretty sure we are doing things properly,
ie everything is done from within PN, but when we do it from one machine we
get one path and drive letter and when we do it from another machine we get
a different path and drive letter.
so i guess we fixed it, it was just a pain.....and dont know what we would
do differently next time.
thanks again
steve
"William Fitzpatrick - autodesk"
wrote in message news:42324051_3@newsprd01...
> Steve,
> What you are describing is not normal. Have you moved the project or dwgs
> within the project via Windows Navigator? It would be helpful if you could
> explain a bit more about how the Project was set up and how you are
> creating new dwgs. I.e. Were existing dwgs dropped to the PN folders or
> were dwgs created from scratch (Constructs > New Construct...etc.). Are
> you using the PN to create new Views using the UI? Are you dragging Views
> from the View tab onto new Sheets to create new Viewports?
> Fitz
> Autodesk
> "steven oyer" wrote in message
> news:4231e6c0_3@newsprd01...
>>i am using the PN to set everything up and xref everything....
>> but once set up and a file is then lost I use the xrefe manager to
>> reattach it
>> is there a better way, the repath command does not solve the problem
>> thanks
>> steve
>> "David_W._Koch" wrote in message
>> news:8955529.1110563726281.JavaMail.jive@jiveforum2.autodesk.com...
>>> If you are setting up your files through the Project Navigator, the
>>> proper XREF types should be assigned automatically [attach vs overlay],
>>> the proper data should be entered in the XML files and the views and
>>> sheets should have the files you want.
>>> Are you manually adding external references to you files outside of the
>>> Project Navigator [ie, using the XREF Manager]?
>>> David Koch
>>> Autodesk Discussion Group Facilitator
