Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
137 Views, 3 Replies
Write to PDF?
Can anyone walk me through the steps required to save a drawing as a PDF
file using desktop? We are looking to send drawings to clients but we don't
have Acrobat. Any easy-to-follow help would be very appreciated. Thanks in
advance.
M. Johnson
3 REPLIES 3
Hi there,
Before the inevitable onslaught of "you should search the newsgroup for
this" replies comes flying your way, I'll tell you that we use Pdf995 here
(http://www.PDF995.COM) and it works great. You could download that (it's
free) and then install it (follow the on-screen directions) and then you'll
be able to print to a pdf from adt. We do it all the time and it gives us
nice results.
Hope that helps.
Paul
If it ain't fun, it ain't worth it!
http://www.linetype.com/advice/pdfcreation/index.htm
http://www.tenlinks.com/CAD/USERS/AUTOCAD/ADDONS/output/pdf.htm
Free PDF writer:
http://www.acrosoftware.com/
Here is a link from Adobe that shows how to use Adobe Acrobat and
AutoCAD.
http://www.adobe.com/products/acrobat/pdfs/enghowto.pdf
The next link is also from Adobe:
http://www.adobe.com/support/techdocs/19ac2.htm
AutoCAD tip: Plotting PDFs
http://www.cadalyst.com/newsline/issue.cfm?issue=200225#8
More tips for making PDF files in AutoCAD
http://www.cadalyst.com/newsline/issue.cfm?issue=200226#6
More notes on the PDF file format
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#4
PDF software: Adobe alternatives
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#5
PDF software: Part of a plotting package
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#6
PDF software: Free downloads
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#7
PDF software: Jaws PDF Creator
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#8
PDF software: PDF-XChange
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#9
PDF software: View Companion
http://www.cadalyst.com/newsline/issue.cfm?issue=200227#10
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
BUY THIS PRODUCT!!!
I use it all day. It is worth the full suite cost of $19.95!!
Reid M. Addis
Registered Architect
Architectural Applications Specialist
Granary Associates
411 North 20th Street
Philadelphia, PA 19130
Ph. 215-665-7056
email: addis@granaryassoc.com
