Well basically if you don't want to change what will fix the problem you
will be out of luck. 🙂
I find the default setting too low and raise it anyway.
If you don't have any low windows and all your heads are much the same, then
raise the global setting.
If you do have some low windows you can
1. raise theglobal setting and over-ride the walls with low windows
2. over-ride the wall you have posted
Which?- depends on how many of each in the project.
But it's not a big deal to change the global setting.
If you have a wall with both low & high you are out of luck and will need to
add a workaround like a mask etc.
wrote in message news:6005021@discussion.autodesk.com...
In the attached file I have a wall with two window assemblies. One window is
above the cut plane and I can't make is display correctly for the
Presentation display representation. Can one knowledgeable users give a hand
and tell me what I need to adjust to correct the problem? I'd prefer not
changing the cut plane of the wall. This is a ADT 2006 file.
