IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Window Assembly - Equal Divisions
4 REPLIES 4
194 Views, 4 Replies
This seems simple enough to do, but I can't figure it out. Is there a way to make a Window Assembly (or Curtain Wall), that has 4 divisions in which the outer two division widths are equal and the inner two division widths are equal? Each inner unit needs to be about 2/3 larger in size than each outer unit, and stay proportional if the entire unit increases in length. Is it possible? I've attached a file showing what I'm trying to do with linework.
4 REPLIES 4
Here you go, try the attached file.
I inserted a standard WA, then go into the WA Style Properties, Design rules
tab. Change the default division to be "Fixed number of cells" with 6
vertical. Set the "start offset" and "end offset" to 2", then OK out of the
dialog.
Then go to an iso view, select the WA, rt-click, design rules, transfer to
object.
Select WA, rt-click, infill, show markers.
Select WA, rt-click, infill, merge, then select the second from start
marker, then the third from start marker. Then repeat the merge operation
with the opposite end markers.
Select WA, rt-click, infill, hide markers.
Select WA, rt-click, design rules, save to style. Make sure you place a
checkmark in the "Transfer merge operations to style," then click on the New
button and enter a name for your new WA style, and you're done.
HTH,
Chris
Chris Needham Design & Draughting
Whangarei
New Zealand.
wrote in message news:4945819@discussion.autodesk.com...
linework.
Very clever.
David Koch
Autodesk Discussion Group Facilitator
Oh my gosh... That was brilliant. Thank you.
Thanks both David and Kiersten. It's great to be able to help.
wrote in message news:4949029@discussion.autodesk.com...
