You can email me the debug file as well as the status result if it doesn't
say anything to you .
Best Regards, Jimmy Bergmark
Owner/Developer - JTB World - Software development and Consulting
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) - http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
"desgnr" wrote in message
news:5238409@discussion.autodesk.com...
Jimmy:
What do i look for in the debug file ?
"Jimmy Bergmark" wrote in message
news:5238258@discussion.autodesk.com...
Take a look at the tab "Server status".
Take also a look at the debug log file. (Found at the tab Config Services)
news:5238243@discussion.autodesk.com...
Jimmy:
I did that.
ADT still wont start.
When i open Flexlm it says using license server.
I have to stop & restart the server to get ADT to open
Are there any other setting i'm not aware of ???????????
news:5238172@discussion.autodesk.com...
Start lmtools.exe on the license server
Config Services tab
Check "Use Services"
Check "Start Server at Power Up"
news:5237621@discussion.autodesk.com...
Why does'nt Flexlm restart with each bootup.
The only way i can use ADT 2007 is to stop the Flexlm server & restart it
manually,then start ADT 2007
