have you ever received any help with this problem? i've been inconvenienced with this problem while using autocad mep 2011.
my problem happens during dimensioning using linear, continue, and aligned. i can get in a few dimensions, with a bit of a lag between a few seconds to almost a minute, and then it crashes leaving this popup message:
"FATAL ERROR: Cannot write to undo file (probably disk full)"
the program allows me to save a recover file of the drawing, then shuts down completely. at the same time, another popup opens asking you to fill out information on what exactly you were doing when the system crashed. well, after about a hundred times i quit filling that space out.
i'm running a dell m6500 laptop
core i7 q720 @ 1.6ghz
8gb ram
ati firepro m7740 vidcard @ 1gb ram (driver v 8.681.0.0)
autocad mep 2011 (from autodesk revit mep suite 2011) 64-bit
window 7 pro 64-bit
