I can fully understand your feeling of frustration.
I started a whole new office jumping straight into ADT (3.3) with a new
Boss, New job description (a whole lot different to what i had been doing)
and ADT.
My suggestion would be to get people using walls and doors 1st. There are a
few learning issues with cleanups & display reps, but walls & subsequently
inserting doors is pretty basic stuff.
You should also read up chapter 5 of paul aubin's "mastering ADT". Its all
about drawing management principals and you will need to get everyone up to
speed with that or they'll be frustrated - but once you get your head around
constructs, views etc its worth it. Theres a free download of chp 5 on his
website. Many,many people have recommended paul's book.
Once you get a grip on walls & doors and things such as setting display reps
for 1:100 scale, detail scale & ceiling plan you'll wonder why you weren't
using it sooner - also ADT2005 allows you to install common tools & stuff to
a server location so everyone uses the same standard.
To give u an example - my old office to prepare a sketch plan drawing with
solid colour for the shop areas, solid hatch to the walls etc we would end
up with 3 drawings - a base drawing of the plan then another dwg with the
solid colours & then 3rd drawing was title block sheet that everything got
xreffed into. Of course you know what happens when a doors or a wall moves -
editing the 2 base drawings back and forth etc.
now draw a wall - insert a door (cuts the wall & htaching 4 u) then set
display representation - what do u want cd or presentation - i'd use ADT
solely for walls, doors & windows if nothing else - its just so much faster
then manual autocad.
by the way - you can insert doors without having a wall - you just hit
return when it asks you to pick the wall and it will then insert un-anchored
door. u have to trim the wall of course but you can insert a door tag and
then schedule from that
anyway - i hope this encourages you - first thing i'd do if i was you - by
Paul's book and read it up
Regards
Ken
Along with
"JEMCAD" wrote in message
news:10630750.1090241557407.JavaMail.jive@jiveforum1.autodesk.com...
> We have ADT in our office, but like many others, I suspect, we don't
really use it. It was purchased prior to me arriving here, with the idea
that it is AutoCAD for Architects.
> I wanted to slowly introduce ADT to the office on their existing projects
and I'm starting to feel overwhelmed. I thought we could get our feet wet
with using some symbols, door or room tags or a column bubble. And I come
face to face with the irony of ADT and their "all-or-nothing" attitude. As
far as I can tell, you can't just plop a door tag on existing lines and arcs
and fill in attributes, like you could with "AutoArchitect" and Softdesk.
No, you have to pick a door. In order to have a door, you need walls! Same
with a room tag, you need to pick a space! Or a grid for column bubbles!
Come on, give me a break! We have existing Vanilla AutoCAD drawings here.
> This attitude makes it impossible to implements ADT for existing projects.
We would have to redraw the whole bloody project just to use some of the
symbols. Why can't they be more flexible and allow non-ADT objects to be
tagged by filling in attributes.
> As things stand, I can never see us using ADT in the office, for the
implementation is so steep.
> I'm very open for suggestions and advise how to soften the implementation
and make the switch easier, so please advise.
