Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
schink
251 Views, 1 Reply
wallcleanup
Why is the drywall extending to the back of the siding.
Priority for drywall is set at 1210 and the siding is set at 810. Stud is at 500.
1 REPLY 1
David_W_Koch
in reply to: schink
Do you have a component in the space between the siding and the stud?  Even if it is an air space, you should have a component there.  Look at some of the out-of-the-box exterior wall styles.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
