Hi Ed;
I must not be recreating your wall/opening correctly. Take a look at this
file and let me know what's different, or post an example.
Charlie Busa
"Ed Jobe" wrote in message
news:41af6358$1_2@newsprd01...
> Thank you Charlie. But when I set the endcap for the wall to Standard
(None
> is not available) that causes a conflict with the endcap for the opening
> (which wraps the stud) when the two coincide, i.e. the opening is all the
> way to the end of the "vertical" wall. If I choose Standard for the
> opening's endcap, then the stud shows through on the other side of the
> opening. aargh. I would think that somebody's run into this before?
> Ed
> "cbusa" wrote in message
> news:41af5219$1_1@newsprd01...
> > Hi Ed;
> > If you select the vertical wall and grip edit the baseline end to the
> inside
> > face of the horizontal wall the two wall will not clean up. This is
> assuming
> > that the baseline of the horizontal wall is not on the "inside" on the
> room.
> > Then select the vertical wall, Right Click, cleanups and merge the wall
to
> > the horizontal wall. If you need a clean model view override the endcap
> > style of the vertical wall and set this end to "None"
> > I believe this will give the display you want
> > Charlie Busa
> > news:41af49bf$1_1@newsprd01...
> > > I tried both. The cleanup group has no effect on the opening's
endcaps.
> If
> > I
> > > put the wall that has the opening in another cleanup group, the wall
> > doesn't
> > > cleanup at all. I still need it to cleanup at the upper portion where
> the
> > > header is, just not at the opening. I tried using an offset bottom on
a
> > new
> > > wall style, but as I suspected, the gwb does not wrap the bottom.
> However,
> > > this is the best workaround I have so far...if I don't need to render
a
> > view
> > > that shows the underside of the header. I would appreciate any other
> > > suggestions. I'm still trying to learn adt.
> > > Ed
> > > news:41adf89e$1_2@newsprd01...
> > > > I tried making different endcaps, but not different cleanup groups.
I
> > also
> > > > thought of using a segmented wall, but if I just offset the
baseline,
> > > would
> > > > the gwb wrap around the underside of the header?
> > > > Ed
> > > > "Ken"
> wrote
> > > in
> > > > message news:41ad46af_1@newsprd01...
> > > > > or over-ride the cleanup on that end to "no" - i'm not sure but
off
> > the
> > > > top
> > > > > of my head
> > > > > K
> > > > > "Charles C Vincent" wrote in message
> > > > > news:41ad175e$1_1@newsprd01...
> > > > > > Ed,
> > > > > > You could try to have different cleanup groups for those walls.
> I've
> > > > faced
> > > > > > the same situation and that was the only way I could find out of
> it.
> > > > > > Now there's another way: get rid of the opening and use a base
> line
> > > > > > offset instead - always keeping the same base height, though.
> > > > > > hope that helps.
> > > > > > Charles
> > > > > > Ed Jobe wrote:
> > > > > >> Must have hit the file size limit. Here's the second one.
> > > > > >> Ed
