Bret,
I have not tried it, but you might be able to site the justification to the
inside face of the wall, the cleanup to the justification line, and then
create an endcap. I am not sure about this one. Whatever endcap is used it
can not interfere with the window, I know that much for sure. I have on
some similar situations moved or shrunk the window by 1/256" and had that
work. I am not sure that anything is possible for this condition. It is
probably something for a developer at Adesk to attempt.
Good luck.
Robert
"Bret Tushaus" wrote in message
news:36AA54223E9B06B3BC0A0B1D3D345B1A@in.WebX.maYIadrTaRb...
> Thanks for the reponse, what you did makes perfect sense...I should have
> been able to come up with that.
> I was wondering if you had any ideas on how I can make the endcap on the
> horizontal window at the inside corner appear correctly? The brick from
the
> veritcal wall should really continue to the insulation at this opening.
> However, if I try and apply a custom endcap to this opening to reflect
this
> condition, I get a cleanup error. Any ideas?
> "Robert Connor" wrote in message
> news:774C1B9B25E498785172AD868E71CD0C@in.WebX.maYIadrTaRb...
> > Bret,
> > I just found your post from the 12th, and I have posted a solution to
CF.
> > Robert Connor
> > Thielsen Architects
> > news:C36A918D7BEE54BB4DB0BBFFE0CF1FD4@in.WebX.maYIadrTaRb...
> > > I have a condition that I am unable to get the walls to cleanup
> properly.
> > > Basically the condition consists of windows that are in a length of
wall
> > > that is basically the same width of the wall - where the window ends,
> the
> > > wall turns the corner. I am getting wall cleanup errors in two of the
> > walls
> > > involved and I cannot figure out how to resolve the cleanup problem.
> > Where
> > > the wall is broken for the opening, all the endcaps should use the
> endcap
> > > for that wall style in which the brick component returns back to the
> rigid
> > > insulation. I have posted the drawing in the Customer Files group
under
> > the
> > > subject "Wall with Window Cleanup Problem". If anyone has any ideas
on
> > how
> > > I can resolve this, I would greatly appreciate the assistance.
Thanks.
