I have 4 machines on network that I can replicate this problem. I have 3
drawings open, and plot a small area of each drawing. When the third
drawing is sent to the plotter or shortly afterwards, the NT 4.0 workstation
will blue screen with STOP: 0x0000000A errors in ntoskrnl or rdr.sys. I
have verified that the machine has plenty of free memory and is not
stressing the CPU. I also have other machines on the same network that will
work fine. This also occurs plotting to multiple plotters from these
machines.
I have updated plotter drivers on the server, reinstalled Service pack 6a on
the workstation, and installed Service Patch 2 from Autodesk. I have also
run chkdsk on the machine and also ran chkdsk /r and no problems were found.
The stop codes are:
STOP: 0x0000000A (0x00001000, 0x0000001c, 0x00000000, 0x801173a9)
IRQL_NOT_LESS_OR_EQUAL *** Address 801173a9 has base at 80100000 - ntoskrnl
STOP:0x0000000A (0x00000043, 0x0000001c, 0x00000000, 0x80114922)
STOP: 0x0000000A (0x00000010, 0x00000002, 0x00000001, 0x801276d5)
STOP: 0x0000000A (0x00000002, 0x0000001c, 0x00000000, 0x801137a9)
STOP: 0x0000000A (0x00002000, 0x0000001c, 0x00000000, 0x801193a9)
STOP: 0x0000000A (0x00000053, 0x0000001c, 0x00000000, 0x80114922)
These are basically the ones I get with different addresses in them. But
all are the 0x0a type with IRQL_NOT_LESS_OR_EQUAL and most are with
ntoskrnl. I have only had one or two with rdr.sys.
John
