Autodesk Architectural Desktop 2007 & Prior
Active Member
barneclo
Message 1 of 8 (1,170 Views)
Utility brick hatch download?
1170 Views, 7 Replies
05-19-2005 12:16 PM
Where can i find a hatch download for standard utility brick pattern? (4"x4"x12")
Active Member
tswiezy
Message 2 of 8 (1,170 Views)
Re: Utility brick hatch download?
09-14-2006 06:51 AM in reply to: barneclo
I'm looking for the same. Utility Brick, 1/3 Bond.
Anyone got it?
*Hugh Adamson
Message 3 of 8 (1,170 Views)
09-14-2006 05:52 PM in reply to: barneclo
What bond? What are the brick and bedding dimensions? There are a LOT of
brick patterns out there. It may be amongst the links to hatch pattern
collections here:
http://www.cadro.com.au/hatchkit/HatLinks.html
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Active Member
tswiezy
Message 4 of 8 (1,170 Views)
09-15-2006 07:02 AM in reply to: barneclo
4" x 4" x 12" Utility Brick, 1/3 Bond. I've look through the links already. Did not see one there. Thanks.
Distinguished Contributor
David_W._Koch
Message 5 of 8 (1,170 Views)
09-15-2006 09:19 AM in reply to: barneclo
You probably could have created your own custom hatch by now. Open up [a copy of] the acad.pat file and find a hatch pattern definition for a brick pattern that is close to what you want. Read through the Help section on creating custom hatch patterns, then work out which parameters need to be tweaked to get 4" separation on the horizontal lines, 4" dashes and 4" gaps on the vertical lines, a 12" offset on the first set of vertical lines and a 4" vertical and horizontal offset between the first set of vertical lines and the second set of vertical lines [maintaining the 12" offset on the second set], creating the 1/3 running bond.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
*Hugh Adamson
Message 6 of 8 (1,170 Views)
09-15-2006 08:59 PM in reply to: barneclo
Try the attached .PAT file (dropping the .txt filename extension).
*THIRDUTILITY,12"x4" nominal utility brick 3/8" mortar
; Pattern written by HatchKit v2.6 Hatch Pattern Editor
; HatchKit v2.6 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2006.
; www.cadro.com.au/hatchkit/
;-Comment =Adesk newsgroup
;-Date =16/09/2006
;-Time =1:52:23 PM
;-HatchKitVersion=2.6.0.1468
0,4,4,0,8,11.625,-0.375
180,11.625,3.625,0,8,11.625,-0.375
-90,0,3.625,0,12,3.625,-4.375
90,15.625,4,0,12,3.625,-4.375
-90,4,7.625,0,12,3.625,-4.375
0,0,0,0,8,11.625,-0.375
180,15.625,7.625,0,8,11.625,-0.375
90,11.625,0,0,12,3.625,-4.375
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Active Member
tswiezy
Message 7 of 8 (1,170 Views)
10-01-2006 02:05 PM in reply to: barneclo
Ok, Thanks...I'm using a simpler pattern without the bedding. My next question is this:
I have acad.pat in several directories, and have gathered many other custom hatches. How can I put these all in another specific directory, such as ...support/hatch/custom.pat, that AutoCAD will see in the Custom Tab in Hatch command?
Thanks.
Active Member
tswiezy
Message 8 of 8 (1,170 Views)
10-01-2006 07:08 PM in reply to: barneclo
I have created two patterns...my 1/3 utility, and a half height cmu.
But it does not like something about the names of the two files. It would not preview or load either pattern until I deleted every special character in the names (i only used dashes "-"), and all comments in the file except the actual data.
What are the rules for naming and adding text to a .PAT file?
I've attached an offending file.
Thanks for the help
Tom
Announcements
Need installation help?
