IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Utility brick hatch download?
7 REPLIES 7
Message 1 of 8
barneclo
4832 Views, 7 Replies
Where can i find a hatch download for standard utility brick pattern? (4"x4"x12")
7 REPLIES 7
Message 2 of 8
tswiezy
in reply to: barneclo
I'm looking for the same. Utility Brick, 1/3 Bond.
Anyone got it?
Message 3 of 8
What bond? What are the brick and bedding dimensions? There are a LOT of
brick patterns out there. It may be amongst the links to hatch pattern
collections here:
http://www.cadro.com.au/hatchkit/HatLinks.html
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Message 4 of 8
tswiezy
4" x 4" x 12" Utility Brick, 1/3 Bond. I've look through the links already. Did not see one there. Thanks.
Message 5 of 8
You probably could have created your own custom hatch by now. Open up [a copy of] the acad.pat file and find a hatch pattern definition for a brick pattern that is close to what you want. Read through the Help section on creating custom hatch patterns, then work out which parameters need to be tweaked to get 4" separation on the horizontal lines, 4" dashes and 4" gaps on the vertical lines, a 12" offset on the first set of vertical lines and a 4" vertical and horizontal offset between the first set of vertical lines and the second set of vertical lines [maintaining the 12" offset on the second set], creating the 1/3 running bond.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
Message 6 of 8
Try the attached .PAT file (dropping the .txt filename extension).
*THIRDUTILITY,12"x4" nominal utility brick 3/8" mortar
; Pattern written by HatchKit v2.6 Hatch Pattern Editor
; HatchKit v2.6 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2006.
; www.cadro.com.au/hatchkit/
;-Comment =Adesk newsgroup
;-Date =16/09/2006
;-Time =1:52:23 PM
;-HatchKitVersion=2.6.0.1468
0,4,4,0,8,11.625,-0.375
180,11.625,3.625,0,8,11.625,-0.375
-90,0,3.625,0,12,3.625,-4.375
90,15.625,4,0,12,3.625,-4.375
-90,4,7.625,0,12,3.625,-4.375
0,0,0,0,8,11.625,-0.375
180,15.625,7.625,0,8,11.625,-0.375
90,11.625,0,0,12,3.625,-4.375
Hugh Adamson
Cadro Pty Ltd
www.cadro.com.au
Message 7 of 8
tswiezy
Ok, Thanks...I'm using a simpler pattern without the bedding. My next question is this:
I have acad.pat in several directories, and have gathered many other custom hatches. How can I put these all in another specific directory, such as ...support/hatch/custom.pat, that AutoCAD will see in the Custom Tab in Hatch command?
Thanks.
Message 8 of 8
tswiezy
I have created two patterns...my 1/3 utility, and a half height cmu.
But it does not like something about the names of the two files. It would not preview or load either pattern until I deleted every special character in the names (i only used dashes "-"), and all comments in the file except the actual data.
What are the rules for naming and adding text to a .PAT file?
I've attached an offending file.
Thanks for the help
Tom
