Make three different dim styles
1"=1' 12"/1" =12 (your dim scale factor) set text and tick
mark etc to actual size required
1-1/2" = 1' 12/1.5= 8 (your dim scale factor) set text and tick mark
3/4"=1' 12/.75= 16 (your dim scale factor) set text and tick mark
Scale your viewports to the scale required, ( Hope you use paper space) If
you use model , mutiply all your settings required by the scale factor in
each dim style i.e. 1"=1' your text would be 3/4" x 12 = 9" text and so on
wrote in message news:5552796@discussion.autodesk.com...
ok, I am a civil designer that is having a hard time wrapping my brain
around architectural units. I have a project that has several drawings with
different units. The client wants dimension ticks to be 1/4", dimension
arrows to be 1/2"; all text (including dimension text to be 3/4".
the scales are 1"=1'
1-1/2'=1'
3/4"=1'
Could someone please help me with the set up for the dimstyle, general
setup, and text height
I really feel like a dummy, but have been working in engineering units for
18 years.
thank you
Linda
