Autodesk Architectural Desktop 2007 & Prior
Distinguished Contributor
0 Kudos
Post 1 of 2
undesirable lines :-<
28 Views, 1 Replies
09-24-2001 01:12 AM
when i make a wall ("wall1") and change it's roof line i a way that one end is lower then the other, everything is fine unless another wall ("wall2"), lower then the high point of wall1 is touching or crossing wall1. when the connection is there i get in isometric views a line throughout wall1 in the height of wall2. what's happening?? i don't recall this in previos versions :-[
Ella Reshef
*[Autodesk], Bill Glennie
Post 2 of 2
Re: undesirable lines :-<
10-08-2001 04:24 AM in reply to: ELLA
Ella - I only get this effect if Wall1 is curved. Is this the case for you?
If so, this is a known problem, and occurs even if the roofline is not
modified - just having wall1 higher than wall2 will make the additional line
appear. This has been the case since ADT1. The same effect happens with
partial height Wall Modifiers on curved walls. In both cases, this is due
to the need to "re-facet" the exact arc of the wall above and below top of
the intersecting wall or modifier.
Note that you CAN use the Wall Merge option to eliminate the dividing line.
This will preserve the cleanup in plan, but can make it tricky to get
perfect cleanup, because the wall will not automatically extend or shorten
itself at the intersection.
Sorry for the slow reply. I had marked this for later followup, but got
sidetracked by other duties.
Bill Glennie
Autodesk Building Industry Division
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
