I am not having that problem with ADT3.3. Are you using ADT2.0 or ADT2i? If so, go to Point A, and select Knowledge Base from the Product Support pull-down menu. Search for Article TS47474. There is a workaround for ADT2.0; for ADT2i you should install the latest service pack.
David Koch
Member of the Autodesk Discussion Forum Moderator Program
