IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
UCS orientation in multiple viewports
1 REPLY 1
169 Views, 1 Reply
I have my model space screen divided into 3 viewports, each viewing a 3d object from different angles (ie. plan, front and sw iso). what do I need to set in order for the ucs to change in the same fashion in each view port when i select a different UCS? Autocad used to be able to do this. Now it seems it only changes the UCS in the active viewport.
Any help would be appreciated.
Patrick
1 REPLY 1
Patrick,
Try checking the status of the UCSVP variable in
each viewport.
HELP document about UCSVP:
Type: Integer
Saved in: Drawing (viewport
specific)
Initial value: 1
Determines whether the UCS in viewports remains fixed or
changes to reflect the UCS of the current viewport.
0  Unlocked; UCS reflects the UCS of the current
viewport
1  Locked; UCS stored in viewport, and is independent
of the UCS of the current viewport
size=2>------------------------
Alfredo Medina
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">I
Any help would be
appreciated.
Patrick
