Show only
Search instead for
I am applying solid color hatches to some areas on a plan. I would like
the hatch color to be somewhat transparent so that lines or images below can
be seen. Can I do this with AutoCAD?
Huck, I do this a lot.
But all I do is use a light color (yellow for instance)
I also use ANSI31 @1.0 scale.
I simply tell it to "send to back" and everything under it should show up.
To start off with; there was only one question asked in the original message "Can I do this with AutoCAD?" and the first word in your message was "NO, you....."
"I would like the hatch color to be somewhat transparent so that lines or images below can be seen. Can I do this with AutoCAD?"
Does "do this" mean making "the (solid) hatch color to be somewhat transparent"?
AutoCAD doesn't support transparent solid color when display on the screen. So "No" is technically a correct answer to his question. The two methods I provided should be working for his purpose, but they are still workarounds.
