IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
TEXT HEIGHT WILL NOT CHANGE
2 REPLIES 2
151 Views, 2 Replies
Using MTEXT and when you change drawing setup scale the text will not change with it. Someone has locked down the height and I can't figure out were it is. Checked the text style and it is set to 0'0". any place else to check and get it so it works again when the scale is changed? thanks
2 REPLIES 2
Open the Mtext, select all text, change the height as needed. You may have a manual override set. -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Unless you are running a custom routine or a third-party package, the height of MTEXT - either already placed in the drawing or the default height for new additions - will not change in response to changes in the ADT drawing scale.
If you are running a third-party package, you would be better served contacting the providers directly.
David Koch
Member of the Autodesk Discussion Forum Moderator Program
