I apologize if this has been mentioned before...I did a search within this
group on the PAN and found nothing that related to this subject. Thanks for
your help, I can't wait to see if this does the trick.
"Reid M. Addis" wrote in message
news:057779BC70FD86A85DFF9607EC3D6032@in.WebX.maYIadrTaRb...
> As mention many times before (did I mention that this has been mentioned
> before ;-0 ) just click again on the scroll wheel. Think of it like a
> flooded engine: you stepped a bit too long on the gas pedal, and now the
car
> doesn't start, so logically you step down and hold down the gas pedal?
> Sounds weird but it works. Same for the scroll wheel. Just click it fast
> once or twice (sort of a smack up side da head) and it should behave.
> Regards
> Reid M. Addis
> Addis Computer Consultants
> 1-800-841-4418
> http://www.addiscomputer.com
> raddis@addiscomputer.com
> "Bret Tushaus" wrote in message
> news:F11E61BF8D6038C6143D147B8E277544@in.WebX.maYIadrTaRb...
> > I have a few users that are using ADT3 with service pack 2 on Windows 98
> > machines with basic Microsoft Intellimice. Occasionally when using the
> > wheel button to pan, they will get stuck in the Pan command. The
computer
> > does not freeze up, instead you are literally stuck in the command. You
> can
> > continue to Pan, however hitting ESC or Enter or anything else has no
> > affect. The only way to get out of it is to do a CTRL-ALT-DEL and end
the
> > task (without the ability to save changes to the drawing). At this
point
> it
> > does not appear as though this behavior is associated with any specific
> > drawing. Any ideas?
