From what I can see Greg started this thread a long time ago. Greg, what
model of dell does he have? Does this system use an intel 875 chipset?
Does any when else out there having this problem have specific mobo &
chipset info to share. I have two clients with this problem both on an
intel 875 chipset. I established a case with autodesk through the reseller
support channel 3 weeks ago and it has yet to be resolved. The problem is
prevelent regardless of dwg, o/s, video card type & more. Switching to a
PCI video card typically will stop this bad zoom behavior.
Joe Schmidt
"Gary Higgins" wrote in message
news:23044453.1091205098151.JavaMail.jive@jiveforum2.autodesk.com...
> Hi Jeff, you're correct. It doesn't happen on ALL my drawings with TTF's
on, just a select few, say 2 out of 10.
> I'm struggling to find the common link I must admit.
> The only way I've found of curing the problem is rebooting and starting a
clean session. Closing ADT and restarting the program will have a temporary
effect but as you say, within 5 - 10 commands the problem returns.
> Lets hope some bright spark from Autodesk actually reads this and they can
pull thier finger out!!!!
> I can provide drawings that exhibit this strange behaviour if anyone from
Autodesk wants them.
