Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
96 Views, 3 Replies
Stairs
Is there a way to model winding stairs in the shape of an S with the bottom
step flared? I would like to be able to tweak the sides to fit a shape. It
seems that the stairs created are somewhat rigid.
Robert
3 REPLIES 3
Robert
At this time this functionality is not available. You would have to use some custom objects to produced the desired results.
However, this is an area that should be included in the next full release of Arch Desktop. They are making some nice improvements
to the stair routines and this should be possible with the new tools.
Tony
Discussion Moderator
WW Support & Services, Autodesk
Discussion Q&A: http://discussion.autodesk.com
"Tweed" wrote in message news:2925823802DA20B49003531DEEEF86D0@in.WebX.SaUCah8kaAW...
> Robert
Does anybody know if there is a way to make a stair that will go up in a 90
degree angle in one side and follow a circular wall on the other?? This is
on 2i version??
Nato
EGA
Sounds like two stairs to me.
You posted in the ADT1 newsgroup. Since your version is ADT2i, you'll
probably get better results in the autodesk.aec.arch-desktop2 group.
Dave Byrnes/Bowen Island BC
Autodesk Forum Moderator Program
Fortunato Zuazua wrote in message
news:2207FBE54F758FB49E3E992C44FDCD1A@in.WebX.maYIadrTaRb...
90
is
> on 2i version??
> Thanks
> Nato
> EGA
