Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Slow changing directories
2 REPLIES 2
73 Views, 2 Replies
Whenever I try to open files, either locally or over a network the open
dialog box takes forever to preview or change directories. This is the only
machine with the problem.
Does anyone know of a solution?
2 REPLIES 2
Dead or empty links or shortcuts, renames/remapped drives, or updated
drivers that cause PC3 files to become invalid, somewhere in your AutoCAD
search path is causing all of this. Find out what changed, and what should
have, problem should go away.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
It's a fresh reinstallation of Autocad. All the search paths are correct
and the network drives that are pathed are still pathed correctly.
"Dean Saadallah" wrote in message
news:2764CE93820485B8F215D66D2CFE08A6@in.WebX.maYIadrTaRb...
> Dean Saadallah
