To add to Wes' great overview, there is a tutorial that walks you through
the process of converting your old titleblock template to use the new
features.
http://autodesk.blogs.com/between_the_walls/2004/03/create_your_own.html.
I also suggest looking at the out-of-the-box sheet templates (dwt), such as,
Aec Sheet (Imperial Stb).dwt.
Also of note is that when you create a new project in ADT, the sheet set
file (.dst) is automatically created for you. You will just need to edit it
to suit your needs after the fact. A new sheet set should also be created
when you open an ADT 2004 project in ADT 2005.
Finally, the 'Architectural Desktop User's Guide' covers this under the
topic: 'General Information' > 'Drawing Management' > 'The Project
Templates' and under 'Creating a Sheet Set Template'.
chris yanchar | product designer
building solutions division | autodesk, inc.
"Wes Macaulay" wrote in message
news:4091fb1a$1_3@newsprd01...
OK - here's an overview.
You got your DST file which stores all the sheet set data...
You got fields now which make smart callouts...
ADT section, callout and elevation annotations have these fields in them to
work with the Sheet Set / Project Navigator...
If you want to use your existing titleblock, edit the attributes and insert
a field for the default value. From fields, go to the SheetSetPlaceholder
category and choose what you want from there; the goobledygook that gets
inserted, whether just sitting in a text box or attribute, tells AutoCAD
what to put in for a value. SheetSetPlaceholder is probably the most common
field type you'll want.
The DST file (which in ADT is stored in the same folder as the APJ file)
stores all the data about sheet and view names and numbers; the DWGs look at
this file to get the data they need to fill out the fields. In AutoCAD a
DWG gets some data written into the header which tells it which DST file
it's associated with -- this may be true with ADT too or maybe it's done
with XML: I can't remember which.
Once the elevations or sections or plans are dragged onto sheets in Project
Navigator, the fields fill in automatically. Note that you can associate a
block for the viewport title when you drag and drop the views onto sheets --
another nice touch.
I don't know how many people are going to set up sheet sets in their office,
but they all should. Thanks to DWF and DWF Composer and the inroads that
are being made to use DWFs for large scale reproduction, you really ought to
get sheet sets going in your office even if you have to donate your brain to
science afterward. DWFs are such giddy fun, don't you know!
W.
"hiline" wrote in message
news:6101081.1083086242988.JavaMail.jive@jiveforum1.autodesk.com...
> Is anyone aware of any good tutorials on sheetsets in adt05? The more I
read and the more I experiment, the more confused I'm getting.
> I just want to set up 6 or 8 sheetset templates for different job types,
using my titleblock.
> Thank You,
> Phil
