IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Schedules -- Hinged Double Doors to show as (2)
4 REPLIES 4
452 Views, 4 Replies
Next question on schedules . . . (I'm shooting 0 for 1 so far) . . .
Is there a way to make the "PR" that appears on the door schedule for a pair
of hinged doors (hinged - double) to read as (2) or do I need to make it two
doors?
Annette @ SLaM
azautcke.slam@ntd.net
4 REPLIES 4
You can get it to read 2 @ W x H x T by editing the Property Set Definition
of DoorStyles.
Select the DOORSIZE item and click SOURCE. You will have several choices
there. If you want it to read (2) W x H x T you will need to program some.
| Rob Starz
| Stardsign cad solutions
| AEC Designer / Consultant / Developer
| Arch Desktop tools www.stardsign.com/adtcadpacx.htm
| ******coming soon e-Training for ******
| programming Arch Desktop
| learn what you can do...with little input.
PS.
You will need to modify your Schedule to get rid of the individual W D T and
use the one combined PSD item.
The only thing I don't like about this is that you can't edit the
information. That is why I like using VB to custom program my combined
areas. The program detects the editing of combined cells and then edits the
object as needed.
| Rob Starz
Thanks so very much for your help. My schedule is finally taking shape.
Annette
"Rob Starz" wrote in message
news:3CEF204AAF3FEE3F025DC0F497FD5B87@in.WebX.maYIadrTaRb...
> PS.
and
the
> object as needed.
> | Rob Starz
jorgeseptien
Hi everyone,
I know this is old, but I found where it could be done rather easily.  In my case, I had a door schedule in another drawing and had the doors in floor plan drawing.  I went into the floor plan drawing and in the style manager, under documentation objects>Property Set Definiton, I clicked on the DoorObjects and change the source of the Width to "Door: Width - 2@".  I hope this helps whoever is looking for this.
Jorge Septien
