As it is written, you are technically correct. He was asked to do a
site plan at 1:30. I interpreted that he was verbally asked to do this.
Interpreting what is actually wanted as compared to what is asked is
sometimes necessary, as we have all found out. For a site plan, in
imperial units, this would imply 1"-30'. In imperial unit site plans, a
scale of 1:30 is not a common scale.
David_W._Koch wrote:
> No, 1:30 is a unitless ratio and means just what it says, 1 "anything"
> equals 30 of the same "anythings" - so 1 inch = 30 inches, 1 mm = 30mm, etc.
> 1" = 30'-0" is the same as 1" = 360", or 1:360. That is tweleve times
> smaller than 1:30, so if your siteplan fills your sheet at 1:360, it is
> not surprizing that a view twelve times larger does not fit.
> Type 1:360 or 1"=30' in the viewport scale control on the Viewports
> toolbar or 1/360 in the "Custom scale" property in the Properties dialog.
> David Koch
> Member of the Autodesk Discussion Forum Moderator Program
