Thanks for the reply Chris.
The following is my command string in the custom command in DesignCenter:
_AecAnnoScheduleTagAdd PropertySetDefs.Dwg _SYMBOL "Standard Window Label"
_LEADER _None _DIMSTYLE _Current
In the Insert options, the "anchor type" is NONE, and "Attribute Text Angle"
is As Inserted.
I have tried various combinations of Anchor type and Attribute Text Angle
with the same results.
I'm using the Metric content, with a custom made window tag with two
attributes:-Windowstyles:Width and Windowstyles:Height.
If I drop from design center, the label comes in with the appropriate
attribute values from the window (or assembly) but with a zero rotation.
If I use the WindowLabelAdd command, the label DOES NOT come in with the
attribute values from the window, but does come in rotated to the window
angle.
Also, using the WindowLabelAdd command does not allow me to label window
assemblies, which is what I use mostly.
Do you see anything that I may be doing wrong? I'm sure that I had this
working correctly during the Beta testing, but maybe I'm mistaken...
Thanks again,
Chris.
"chris yanchar - autodesk inc" wrote in
message news:FE30DFE3736427C27F4A3F08BBAA02CB@in.WebX.maYIadrTaRb...
> As far as I can tell, I am getting consistent behavior between ADT 3.3 and
> ADT 2004 using the DACH template and the DACH window labels. I do get
> slightly different behavior, but again consistent between both versions,
> whether I drop from DesignCenter or use the WindowLabelAdd command.
> Hrmm...maybe something special with your content??
> chris yanchar | product designer
> building solutions division
> autodesk, inc.
> "Chris Needham" wrote in message
> news:5A28650B5364A87C324E6F7526332174@in.WebX.maYIadrTaRb...
> > Hmmm, are mARTin and me the only people here that use window tags?
> > I'd really just like to know if this works correctly for anyone here, or
> is
> > it a bug.
> > Please, help.... someone...... h e l p . . . . . . . . .
> > Chris.
> > news:DA2A74D95DA2547D86D1162777511A1F@in.WebX.maYIadrTaRb...
> > > Just re-asking a question posted on 10/-5/05 by mARTin regarding why
> > window
> > > tags don't rotate to align with the windows, or is there something
that
> > > we're doing wrong.
> > > This used to work in ADT3.3.
> > > Autodesk please....
> > > Thanks,
> > > Chris.
> > > Chris Needham Design & Draughting,
> > > Whangarei,
> > > New Zealand.
