Hey Brian,
It is because you have a block with some spaces in it. Purge "temp" block, save the drawing and reopen. That should fix the problem. I have logged this as a bug.
Could this be the problem you had in the other drawing as well?
Scott
"Brian E. Goldman" wrote in message news:405f06f7_2@newsprd01...
I am still having the "ghost" space object problem. To fix the other drawing I copied all the objects out of the drawing and renamed the drawings. Before doing this I moved all the objects in the drawing away from the original positions and found that the spaces that were throwing things off were not moved. Hence making a new drawing. But now I'm have the same problem in another drawing and I would like to know exactly what going on. I emailed the drawing to Scott. The problem occurs at space 124 (Pantry) I have moved the tagged space up. But if you select one of the doors in the Pantry they are reading from a space numbered 122. I attached another property set that would tell me the space style and it is called Fellowship. I tried filtering on spaces with this name and it only shows 1, which it should be 2 if you include the ghost. So what gives?
"Brian E. Goldman" wrote in message news:40559f1d_2@newsprd01...
I have a basement plan w/ spaceobjects and then doors with doorobject psds pulling the location property from the spaceobject. For some reason my doorobject location is 3 off from the spaceobject number. This drove me crazy for 8 hours. Finally I moved the space and moved the location leader to the new location of the space and the numbers matched! I then moved the location leader back to the original position and again the number appear 3 off??? So there is a space present that I cannot see. I turned on/ thawed all layers and I don't see anything. Why is a spaceobject being read by the doorobject??? Please help!? Is there a clean tool??
