Nameless,
My association is plainly visible and I make no bones about it, nor do I try
to hide it, unlike yourself. I don't recall making any comments about "old
timers", and since you chose to sign on with no name and no other
information about yourself, it seems to me you took things a little too
personally.
Regardless, I hold to my original statement. If vellum and lead are more
productive for you, I suggest you stick with them. But I think the numbers
are against you, unless you are suggesting that the majority of architects,
who DO find CADD more productive, when used PROPERLY, are nuts.
It's a tool. Just like a chain saw. Whack a chain saw against a tree a few
times and you'll get a broken chain saw. Until somebody shows you how to
pull the cord.
Or a better illustration is perhaps the one I heard about the motorcycle.
Let's say you ride a bike to work every day for years. Someone gives you a
motorcycle, which you've never seen before. You don't find any pedals, so
you push it to work, thinking "Dang, this is SO in-efficient". Then, you
figure out how to start it, but you can't shift gears, and you can't find
the brakes. Now you're dangerous.
Please do not email me privately with technical issues
Matt Dillon
Assistant Moderator - Autodesk Discussion Forums
The D.C. CADD Company, Inc.
http://www.dccadd.com
........ <.............> wrote in message
<7E5827D9F560FA905F96B1C9897968F4@in.WebX.maYIadrTaRb>...
>They were more efficient. The only thing that CAD has made easier has been
>copying information and editing. This leads to a lower quality of drawings
>because people put less effort into drawings, because they "could be
changed
>easily." Except people run into a little problem. The new technology makes
>it easier to change drawings, and it is supposed to take less time now. So
>firms are caught making last minute changes, and then send out incomplete
>drawings because they ran out of time. Copying details was not that
>difficult. We had something called "sticky back." It worked really well,
and
>it got the information across, with no problem. Architects worried about
>making the drawing read, not about display representations, layer states,
>xrefs, blocks, etc..... This is all so silly.
>If you think that I am biased because I am an "old timer" who cannot model
>in 3D, or use ADT, you are mistaken. I can use most cad programs on the
>market today productively, but I can still keep a critical eye on what is
>important.
>However, your opinion is not biased right, Matt?.... I mean, you are not
>tied into AutoDesk, are you? .......Oh wait, you are.........
