What data type are your room numbers? Do you use integers, or auto-increment integers? What does the formula property you are using look like? The schedule table is interpreting the number-only room numbers as integers and the number+suffix as strings, and, as you have noticed, sorts the strings first, then the numbers. That would lead me to believe that you are using implicit concatenation in your formula property, something like this [your property names may vary]:
[RoomNumber][NumberSuffix]
Try this instead:
"[RoomNumber]" & " [NumberSuffix]"
and you should find that ADT is now interpretting all of the formula results as strings and you should get the sorting you want, assuming that all room numbers have the same number of digits.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
