Autodesk Architectural Desktop 2007 & Prior
*Jonas
Message 1 of 4 (309 Views)
problem with selection sets and dynamic zoom/pan
309 Views, 3 Replies
04-04-2002 01:18 AM
when I select some objects
I pan and zoom with the wheel to select some more
and then I issue a move command
some of the selection falls out of the move command and is not moved
serious bug in AutoCAD as I can see. tisk tisk tisk , somebodys not doing a
very good job IMHO, all the problems in these new AutoCAD versions. so
frustrating and a waste of money for such a buggy product. lower prices and
rebates are in order.
Distinguished Contributor
David_W._Koch
Message 2 of 4 (309 Views)
Re: problem with selection sets and dynamic zoom/pan
04-04-2002 02:03 AM in reply to: *Jonas
I am not experiencing that here for the MOVE command. This effect has been noted for the stretch command and was discussed a few months ago at some length.
David Koch
*Addis, Reid M.
Message 3 of 4 (309 Views)
04-04-2002 03:18 AM in reply to: *Jonas
Not a new issue. If YOU can't see the objects on the screen, neither can
AutoCAD, even if you just selected them before panning. Some view this as a
"feature". What would be nice is, yet another, setvar to allow us to choose
to allow selection sets we can't see.
Regards
Reid M. Addis
Architectural Applications Specialist
Granary Associates
215-665-7056
addis@granaryassoc.com
"Jonas" wrote in message
news:8BE5DC01314E3ADA921932623B90CC96@in.WebX.maYIadrTaRb...
a
and
Active Contributor
bireshwar.mallick
Message 4 of 4 (278 Views)
09-24-2012 11:21 PM in reply to: *Jonas
Yes I had seen this issue in our production floors.Being a Software Engineer and a Research person I had recorded all the issues (that you can say a type of bugs) can be summed as follows:-
  1. Uneven mouse pan issue
  2. Zoom factor issue in autocad environment
  3. Hatch issue (regenerating disappeared hatches)
  4. Selection issue in autocad
  5. Highlighting issue in autocad
  6. Polyline line weight not showing
Your issue is also covered in points 1,2 & 4 of the above mentioned listings.
I have devised a tool named RestoreUpdatedTool which can be uploaded using the appload command and donot foget to do the same appload in the contents folder.I have created a toolbar in which I can show the functionalities of the tool.
Note(B): I will share the tool (the lisp file) for your help.
Bireshwar
