Yes I had seen this issue in our production floors.Being a Software Engineer and a Research person I had recorded all the issues (that you can say a type of bugs) can be summed as follows:-
Your issue is also covered in points 1,2 & 4 of the above mentioned listings.
I have devised a tool named RestoreUpdatedTool which can be uploaded using the appload command and donot foget to do the same appload in the contents folder.I have created a toolbar in which I can show the functionalities of the tool.
Note(B): I will share the tool (the lisp file) for your help.
