"bmiddleton" <This
href="mailto:bmiddleton@dparchitects.net">bmiddleton@dparchitects.net>
wrote in message
href="news:f14f899.-1@WebX.maYIadrTaRb">news:f14f899.-1@WebX.maYIadrTaRb...
is kind of hard to explain, and it just started happening a week or so ago. On
certain plan drawings with a baseplan xrefed into model space, when I open the
drawing with the default view in paperspace, Autocad loads multiple copies of
the xref into paperspace. These copies aren't xrefs, but individual entities.
It then asks "Do you really want to do this?" many times. If I ctrl-c enough,
it finally exits, but if I try to zoom it goes through this same routine. I
have been able to delete these mutiple copies, but the next time the drawing
is opened, the same thing happens. If I audit, no errors show, nor if I try
and recover the drawing. At first I thought it had something to do with a door
schedule that was in the xref because it kept saying something like "Could not
automatically add object to schedule". I think this was only showing up
because of the mutiple copies. Once I deleted the schedule, I no longer got
that error, but it still creates multiple drawings. Also, if I play around in
these drawings enough for Autocad to have a fatal error and exit, and then
open the drawing back up immediately, the drawing seems fine.
So far this has happened to 2 different drawings, in 2 different projects,
with 2 different xrefs. I think it is drawing based since this happens exactly
the same on 3 different computers, but I could be wrong. Does anyone have any
ideas? These are critical drawings and I can't fix them!
Thanks.
Ryan wrote:
I've had the
same problem on a couple reflected ceiling plans. I figured that it has
something to do with hatch boundaries, because in my reflected ceiling
plan had tonnes upon tonnes of sand and dot hatching. I was never able
to fix, I just sort of lived with. If anyone knows how to fix this problem
it would be great. Also in my drawings, if i answered yes to "do you really
want to do this?" when it takes the entire XREF drawing, explodes it and
puts it on the current drawing layer. Which is really annoying to have
to delete.Any feedback is
appreciated.Ryan
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"bmiddleton"
<bmiddleton@dparchitects.net>
wrote in message news:f14f899.-1@WebX.maYIadrTaRb...This
ago. On certain plan drawings with a baseplan xrefed into model space,
when I open the drawing with the default view in paperspace, Autocad loads
multiple copies of the xref into paperspace. These copies aren't xrefs,
but individual entities. It then asks "Do you really want to do this?"
many times. If I ctrl-c enough, it finally exits, but if I try to zoom
it goes through this same routine. I have been able to delete these mutiple
copies, but the next time the drawing is opened, the same thing happens.
If I audit, no errors show, nor if I try and recover the drawing. At first
I thought it had something to do with a door schedule that was in the xref
because it kept saying something like "Could not automatically add object
to schedule". I think this was only showing up because of the mutiple copies.
Once I deleted the schedule, I no longer got that error, but it still creates
multiple drawings. Also, if I play around in these drawings enough for
Autocad to have a fatal error and exit, and then open the drawing back
exactly the same on 3 different computers, but I could be wrong. Does anyone
have any ideas? These are critical drawings and I can't fix them! Thanks.
