John,
This is a known issue with WBLOCK* (entire drawing) when you have an empty
Layer State dictionary. Basically, at one time, there were layer states in
your drawing, but they were removed. The solution is to create a dummy layer
state and then wblock*. Once you open the wblocked drawing, run Audit "Y"
and you should be good to go.
Scott
"John Spangler" wrote in message
news:9A20D2C7E9FB558993B582FB77050BBA@in.WebX.maYIadrTaRb...
> If someone could take a look at the drawing I have posted to customer
files
> called JOHN.DWG with the same subject line, I would appreciate it.
> We have many drawings like this that crash on us constantly. Most of our
> Fatal Errors can be cleared up with the old WBLOCK * over itself. Our
> latest set of drawings now crash when doing the WBLOCK. It is happening
to
> many of the drawings in the same project directory.
> I've tried to dissect the drawing by removing things, but it continues to
> crash. JOHN.DWG is completely empty. No entities, layers, blocks,
> linetypes, fonts, nothing. Completely purged, but it continues to crash
> when I WBLOCK it. Why?
> Thanks for the help.
> John Spangler
> jes@rlfae.com
