The way it works is that the active drawing controls the layers. If you
import a drawing into the active drawing, the imported drawing takes on the
layer properties of the active drawing - unless the active drawing doesn't
contain layers of the same time, of course. What you can do, if you don't
want to take the time to change color, linetype, and other properties in
every layer, is to rename all the layers. You can try this:
-rename
layer
*lizard
Then you can use the LAYER TRANSLATOR to change all the layers to their
correct names and properties.
_________________________
Bill DeShawn
bdeshawn@nospamsterling.net
http://my.sterling.net/~bdeshawn
wrote in message news:5503271@discussion.autodesk.com...
I have a drawing that someone went and changed all of the active layers to a
grayscale color and a very light lineweight, instead of just changing the
xref layers. I need to get my layers back to the way they are supposed to
look. Is there a way to create a new drawing and copy them across and
override the active layers to take on the same parameters of the new file's
layers? I know I can copy them across but can't find a way to get them to
override. Thanks
