In the Options dialog, on the AEC Editor tab, look in the Optimize for Speed area in the left column (third down from top). Is the Object Snap toggle checked? If so, clear the check mark, OK back to the drawing, and see if that resolves your problem.
David Koch
Using ADT 2004 at work; access to 2005-2009 at home
