I'm on the same end as the consultant -- I run the basic program, but I
get files from ADT frequently. What I've found is that the object
enablers don't always give me a workable background. The only thing
that seems to work is when the client with ADT explodes the AEC entities
before he sends the file. Even when I can work with the AEC entities I
frequently have to explode the entities -- magenta seems to be a
favorite color for toilets, but it's also the color we use for a wide
line in all our custom symbols. When I explode an AEC entity using an
enabler the arcs tend to be out of place, so I have to do a lot of
rework. When the guy with ADT does the explode I don't see this problem.
Martin
kevinmukbel wrote:
> A consultant has 2000 ONLY and we are sending ADT R3.3 drawings. He
> downloaded the object enabler but still can't see the ADT
> walls....What's wrong? He downloaded and installed the OBJECT enabler
> for 2000i (Autodesk Architectural Desktop 3.31 Object Enabler) . It
> seems that there is no OE for 2000.
> Which object enabler should he download?
> What is the exact link to it?
> Will he ever be able to see the ADT walls / entities?
> What should the Proxygraphics, proxynotice be set to on his system?
> I hope I don't end up exploding the AEC entities.
> TIA
> Kevin
