IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
not allowed because drawing contains objects from a newer version of
3 REPLIES 3
3inone
3077 Views, 3 Replies
Dear All,
 I got some problem in ADT 2007 when I opening the CAD files and  use the command "aecdwgsetup" it reture the error message "not allowed because drawing contains objects from a newer version of this application." Anyone can help to solve this problem ?
Thanks !
3 REPLIES 3
ntellery
in reply to: 3inone
The drawing has been saved down from a later version? yes?
No way to solve it that I know. Just one of those features adesk gives you for free.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
3inone
in reply to: 3inone
yes, the CAD files save from new version ( AutoCAD 2011) .  Autodesk without other method to fix this problem ?
GREGBURNS5050
in reply to: 3inone
Spoiler
If you are using shortcut icons for the following commands: Fillet, Chamfer, Select Similar you must open your CUI file and edit the macro. Remove the AEC part of the macro line and save your changes.
