For all those that require a more difinative step by step process to
Mapping drives, the following may be of some interest.
Right, best way to do this is with mapped drives
When you at the office and you accessing your server, you should map a
drive to \\server\roo. Right click My Computer - Map Network Drive - Choose
a drive letter you want to use and in the folder area type \\server\roo.
Tick 'reconnect at logon', that will map it every time you boot up. Click
finish, go to My Computer and you will see a drive mapped to that share.
Always work off this mapped drive from now on when opening/saving drawings.
When you are away from your work network and you boot your laptop you might
get a failure message that it cant map the drive, I think there is a tick
box saying that it must ignore the error in future but must always try map
the drive - that's what you want.
Now on your laptop make a folder and share it as whatever, lets say
'laptopshare'. Make sure you set permissions so only you and admins have
access. Copy/update all your work to that folder (keeping the same folder
layout as \\server\roo). When you are away from home map a drive as above
using the same drive letter but the folder to map to is
\\127.0.0.1\laptopshare (dont tell it to map everytime else laptop will get
confused)
This way the laptop/cad doesn't care where the mapped drive is pointing, all
its cares about is the drive letter and because it's the same it should all
work fine. So when you opening your drawings, etc, always open them from the
'mapped drive'. That way cad will think everything is hunky doory whether
working off server or laptop. All make sense??
If the drive mapping to \\127.0.0.1\laptopshare does not work it might be
because you are using service pack 2 of windows xp, to fix this download and
install this patch:
http://support.microsoft.com/default.aspx?scid=kb;en-us;884020
You could also make a batch file that automatically maps the drive when
away from home - you just double click it and it will map the drive- no need
to do it via My Computer.
Make a text file and type the following in the first line, replace
\\127.0.0.1\laptopshare with whatever you shared the folder on your laptop
as and replace the drive letter ( Z: ) to whatever you chose to map as:
NET USE Z: \\127.0.0.1\laptopshare /PERSISTENT:NO
Save the file, now you need to change the extension of the file from .txt
to .bat
Keep this on your laptop and when you away from work just double click it
and it will map the drive to the local share
