IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Moving Projects to a new server
0 REPLIES 0
Message 1 of 1
111 Views, 0 Replies
Hello everyone, I have encountered an odd problem after we upgraded to a new server. I thought this would be simple since we are using Project navigator and it handles the repathing of Xref's but after moving everything to the new server ADT hangs on opening some sheets, I'm talking a minute or more. The project was repathed and everything loads correctly and the latency seems to be limited to files with Xref's. This latency does not show when opening constructs, only *some* views and sheets. Is it possible that ADT is looking for an old UNC path and once it times out it moves to the new path? is there a file to look at for old references. Any suggestions? thanks -k
0 REPLIES 0
