Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
life saftey plans
4 REPLIES 4
169 Views, 4 Replies
life saftey plans
Is there a way to add a line type for fire and smoke barriers to wall styles that could then be displayed with a display rep
4 REPLIES 4
JKemble wrote in message: > Is there a way to add a line type for fire and smoke barriers to wall > styles that could then be displayed with a display rep here's what I do: Setup a New Display Config, and Object Display 1. Create a new Display Configuration: 'Life Safety Plans' or somesuch. 2. Copy the 'Sketch' display for walls. Name the copy 'Fire Rating' 2. set the Wall Object to display: 'Plan Low Detail' *and* 'Fire Rating' 3. modify other Object types for display as you see fit. Modify your Wall Styles Display settings for the 'Life Safety Plans' display. 1. Edit the wall Style Display Setings. 3. for Non-rated walls/partitions modify the Drawing default for the Fire 'Rating' display. Turn off all 3 components. 2. For Rated walls, set a style-based override to the 'Fire Rating' display, Enable 'Centerline', set the linetype, lineweight, etc. That's it. If done correctly: 1. You should have a 'Life Safety Plans' display Configuration. 2. When active, all rated walls/partitions should display a line @ the centerline; which indicate a rating. -- CoreyL
Content Browser\Documentation Tool Catalog - Imperial\Miscellaneous\Fire Rating Lines These lines attach right to a wall.
But do not move with the wall... "D. Matthew Facer" wrote in message news:4162a3f9$1_3@newsprd01... > Content Browser\Documentation Tool Catalog - Imperial\Miscellaneous\Fire > Rating Lines > > These lines attach right to a wall. > >
Thanks "D. Matthew Facer" wrote in message news:4162a3f9$1_3@newsprd01... > Content Browser\Documentation Tool Catalog - Imperial\Miscellaneous\Fire > Rating Lines > > These lines attach right to a wall. > >
