JKemble wrote in message:
> Is there a way to add a line type for fire and smoke barriers to wall
> styles that could then be displayed with a display rep
here's what I do:
Setup a New Display Config, and Object Display
1. Create a new Display Configuration: 'Life Safety Plans' or somesuch.
2. Copy the 'Sketch' display for walls. Name the copy 'Fire Rating'
2. set the Wall Object to display: 'Plan Low Detail' *and* 'Fire Rating'
3. modify other Object types for display as you see fit.
Modify your Wall Styles Display settings for the 'Life Safety Plans'
display.
1. Edit the wall Style Display Setings.
3. for Non-rated walls/partitions modify the Drawing default for the
Fire 'Rating' display. Turn off all 3 components.
2. For Rated walls, set a style-based override to the 'Fire Rating'
display, Enable 'Centerline', set the linetype, lineweight, etc.
That's it.
If done correctly:
1. You should have a 'Life Safety Plans' display Configuration.
2. When active, all rated walls/partitions should display a line @ the
centerline; which indicate a rating.
CoreyL
