IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
54 Views, 1 Reply
Keynote
hi
I have added a leader to my drawing. later when i select this and right-click , when i selected the option keynote(no help was available on this in the software) and specified the first point an alert message is displayed.
if i say yes the ADT 2004 is closing , if i say no a dialog box is opened named "Select Keynote" with 3 options.
where can i find information about this dialog box and in what way is this different from the usual leader.
thanks
devi
1 REPLY 1
What is the exact "alert message" you are receiving? I haven't heard any
problem such as this before.
If you look in the Help system, in "Architectural Desktop Details," under
"Details," you will find the topic "Adding Keynotes to Detail Components."
The main use of the keynote/annotate command is to pull the data from a
detail component, but anything can be keynoted, it just won't be as
automatic.
chris yanchar | product designer
building solutions division
autodesk, inc.
