IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Keynote Legends Shifting Graphically
1 REPLY 1
dhenke1
670 Views, 1 Reply
I have a project where I place my keynote legends on the sheet, get them adjusted graphically how I want them and sync...all other users sync and they appear fine.  We come back the next day, open the project, and find that the fields are elongated graphically on the sheet, such that they are hanging over the designated area on the titleblock.  Any thoughts on what might be causing this bug?
1 REPLY 1
dhenke1
in reply to: dhenke1
I solved my own problem and will post the solution in case anyone else has the same issue.  If you click into a schedule "cell" and click "resize" you can set the hold width of that particular column.  So far, no shifting has occurred.
