Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Installing Architectural Desktop 3.3 on Windows 7
5 REPLIES 5
7164 Views, 5 Replies
I'm retired, doing wood working. I use ADT 3.3 to model my projects. I get a fatel error message when loading, twice. It validates in the beginning of the loading and proceeds.
Is it compatable with the operating system, or is there another problem?
Quatrefoil
5 REPLIES 5
wizakid
I was having the very same problem.  After a long night and early morning of searching for solutions, I finally found one that works for me.  Windows 7 has an XP mode available for download at:
http://www.microsoft.com/windows/virtual-pc/download.aspx
It can be a little diffictul to follow all the steps to get the XP mode installed and working, so be patient and be prepared to search google for more info.  Once installed, you can operate AutoCad 2002 ADT3.3 from a virtual XP platform right on your desktop....AWESOME!!!  You will have to find your CAD files on your harddrive and save them to a shortcut to the XP virtual desktop.
Hope it works for you.  All the best.
WiZa
i want to know if it is possible to run autocad 3.3 on my windows7 machine and if possible how to go about it
thanks
I'm retired, doing architectural designs. I use autodesk architectural desktop 3.3 to model my projects. I get a fatel error message when loading, twice. It validates in the beginning of the loading and proceeds.
pendean
ADT3.3 is note designed to work with Win7.
Its just not compatible with your operating windows,you can try the 2008 is as good as the 3.3
Sent from my iPhone
