Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
I'm stuck in a viewport layout and can't get up... eeer... out!
16 REPLIES 16
Message 1 of 17
mmk20450
296645 Views, 16 Replies
My ADT 3.3 viewports are too close to each other and I can't get out of one without entering another. How do I get into paper space again. I zoomed too far into the selected viewport... now I can't get out. A few months ago someone at work helped me but I don't remember what I did back then. There is no area of paper space showing right now... I am s-t-u-c-k!. Please... any suggestions? Thankz. Meg
16 REPLIES 16
Message 2 of 17
in reply to: mmk20450
If you are in a viewport, ctrl + R will cycle through the viewports.
That what you want?
Steve
"mmk20450" wrote in message
news:f10814d.-1@WebX.maYIadrTaRb...
Message 3 of 17
oops, should have read more slowly....sorry!
"Steve Stafford" wrote in message
news:FF25AF3CFD6FABA8915DF23798322F10@in.WebX.maYIadrTaRb...
> That what you want?
> Steve
one
too
Message 4 of 17
click the Model button at the bottom of the screen
or type PS
Message 5 of 17
mmk20450
Tanks Mike and Steve, I will try the suggestions. There is a terrible storm going on right now in my area (Orlando, FL) Gotta shut down quick due to lotsa lightning! Bye! Be back later...... Meg
Message 6 of 17
mmk20450
Thanks, Mike. PS and ENTER worked! I immediately re-configured the veiwports so it won't happen again. Also- I taped up your suggestion on my desk so I can refer to it again. Meg PS>>> The storm yesterday was horrendous! My 'puter survived though. 😉
Message 7 of 17
CompTIAman
I have a similar situation whereas my viewport is way too big and outside of the Layout viewing area. So, I am not able to get to my viewport in the Layout and panning just moves my drawing around not letting me get to the viewport at all. I have tried a zoom - extents, but due to the fact that I cannot click on the viewport this too does not work. Suggestions anyone?
Message 8 of 17
Mike.Lamka
in reply to: CompTIAman
Increase the size of your layout.  If your stuck in the viewport then you should be able to do as above and type PS then hit enter to get out of it.
Message 9 of 17
ntellery
in reply to: Mike.Lamka
just for the record  Control+R will jump from viewport to viewport.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
Message 10 of 17
ramcharger318
in reply to: ntellery
The Ctrl + R doesn't seem to work in LT.  Is there a way around this?
Message 11 of 17
pendean
in reply to: ramcharger318
LT version?
CTRL+R is a universal AutoCAD feature and also in LT: but it only works if you are inside a viewport to start with and you actually have two or more viewports. Do you? or do you have two viewports that are perfectly overlapping (in which case you need to move one)?
Message 12 of 17
ramcharger318
in reply to: pendean
For whatever reason I had to add a new macro and assign it to the CTRL+R key combination.
Mike Koeninger
Estimator/Project Manager
[cid:image002.jpg@01CEDC5A.2BD94630]
Direct Dial 513-239-5094
Main Office 513-831-2274
Fax 513-831-0206
Message 13 of 17
81204994
Thank yu for your help. Now I be able to continue my drawing.
Message 14 of 17
willjmorton0
I had the same issue where I imported a Drawing from Revit and imported into AutoCAD.  I zoomed in to add a few details, (while in Paperspace) and it would not zoom back out to where I could see the borders with company logo and all the other information. zoom extents didnt work or anything else besides right clicking on the layout tab on the bottom and going into Page Setup Manager and modifying the page again.  After that it zoomed out and centered the drawing.  Hope that helps.
Message 15 of 17
Aryan_jahan
Thanks man. PS saved my life :), otherwise I had to close the program without saving it and then run it again.....
Message 16 of 17
chazie
i think u must use PS command  if you got stuck in resizing the object
CTRL + R is not working
Message 17 of 17
fastardo
I had the same problem. I couldnt reach the extends of the viewport so as to exit from editing it.
I tried typing the command ZOOM extends and didnt work..    BUT it worked when i double clicked the wheel button of the mouse (in which is assigned by default the Zoom extends command).
hope that helps someone
Tags (3)
