If the previous "solutions" don't work, you canuse the divide or measure
commands to lay auxiliary points that you can later connect using PLINE. You
might also need to set PDMODE to something like 3 and PDSIZE to something
like 1 or another suitable size, to see the points (nodes).
Regards from Los Angeles,
Emmanuel
"David Claflin"
wrote in message
news:41928335$1_3@newsprd01...
> If I'm not missing a step, this should work. I'm typing this from memory!
> 1. Change pellipse variable to 1 so that you are drawing old style
ellipses
> ( actually segmented polylines)
> 2. Draw or trace your ellipse.
> 3. PEDIT your ellipse and pick the FIT curve option.
> 4. Trim away the unneeded portion of your ellipse.
> 5. Explode the remaining polyarc ellipse.
> David Claflin
> "Paul Humphrey" wrote in message
news:41927359$1_1@newsprd01...
> > Set pellipse to 1
> > This won't give you arcs, but you'll get consistant vertices at the
arcs.
> > Not sure if this helps, but thought I'd throw that out there.
> > "Cadkiller" wrote in message
> > news:419270c5$1_3@newsprd01...
> > > Group;
> > > I have an elliptical shaped opening and need to convert it to a series
> of
> > > arcs.
> > > Can this type of conversion be done?
> > > Any help would be appreciated.
> > > Thanks;
> > > Edward Borg
> > > Precision Drafting LLC
> > > http://precisiondraftingllc.com
