Thanks so much for your input, especially the expresstools tip. I think
that there may be may be some corrupt information in some of the xrefs as
this project has developed from the first that I did on ADT and I struggled
with some of the concepts to start with.
Cheers,
Mike
"brudgers" wrote in message
news:B6197694F94026BCD9E71AC2396AB98A@in.WebX.maYIadrTaRb...
> "Michael Sealey" wrote in message
> news:5854B94D34606BF4A8A089088336B6B5@in.WebX.maYIadrTaRb...
> > Thanks for the reply. I should have added that HLR fails on the
elevation
> > object also. These are very large drawings with a lot of detail. Works
> > perfectly on small drawings - like the ones that AutoDesk does demos on,
> > haha.
> It may be that there is "corrupt" geometry in the elevation object, or in
> its source xrefs.
> > The thing is, I want to hatch the generated elevations - so DXBs aren't
> good
> > enough as I have to trace new polylines where I want to add hatching,
very
> > detailed hatching, because the lines don't meet.
> Express tools "mpedit" allows multiple join with a "fuzz factor" -
generally
> faster than tracing.
> > Thanks again,
> > Mike
> > news:754E0B545D17BEC3C5ADB1C3E9D26E7D@in.WebX.maYIadrTaRb...
> > > news:ECC83BDC6B9437E602F78F30D117063F@in.WebX.maYIadrTaRb...
> > > > On complex multi-storey buildings (in other words, large files) HLR
> > either
> > > > takes an hour to create its block or fails. Sometimes this crashes
> ADT,
> > > > other times it only creates half the block.
> > > I believe there is a limitation on HLR when using xrefs, I believe you
> > have
> > > to make an elevation object from the combined xrefs then run the HLR.
> See
> > > below for other limitations of HLR.
> > > > The alternative that I use at the moment is to plot to a DXB file
and
> > > bring
> > > > the resulting 2d view back into ADT. There are always (sometimes
> quite
> > > > serious) inaccuracies in the resulting drawing such as lines almost
> > > running
> > > > parallel to one another, over one another or displaces from where
they
> > > ought
> > > > to be. Is there a way of making the DXB plot more accurate?
> > > DXB and HLR both create an image of your drawing. Relative accuracy
> > > (precision) is constant regardless of scale, absolute accuracy varies
> with
> > > scale; the further out you are zoomed the "farther" objects will be
from
> > > their correct position. Zoomed in tight when the image is generated a
> > line
> > > may only be off a tiny fraction of an inch, whereas when zoomed out to
a
> > > large site or elevation the line may be off an inch or more.
> > > > Obviously DXB is far from ideal (it is the only workable solution
that
> I
> > > can
> > > > find) particularly as I lose all layer information. Is there a way
to
> > > > preserve the layer information, or is there another way. I haven't
> had
> > > time
> > > > to play with DWFs yet, could they help?
> > > DWF will flatten your images provided that the Whip viewer CANNOT find
> the
> > > original file. If the DWF and the 3-d DWG from which it was created
are
> > > both on your local machine, opening the DWF will open the original
DWG.
> > > Thus this method requires fooling the ACAD, by renaming or moving
files,
> > > etc.
> > > > I'm getting some great models out of ADT but hidden line plots are
not
> > > good
> > > > enough for some (most) presentations and I really NEED a solution to
> > this
> > > > issue. I would really be rather pleased if the resulting file had a
> good
> > > > level of accuracy also.
> > > > Thanks,
> > > > Mike
> > > > Outgoing mail is certified Virus Free.
> > > > Checked by AVG anti-virus system (http://www.grisoft.com).
> > > > Version: 6.0.227 / Virus Database: 109 - Release Date: 18/01/2001
> > Version: 6.0.227 / Virus Database: 109 - Release Date: 17/01/2001
